I’m doing work for a designer who insists on using 20ga Sterling
Silver as the backing for all bezel mounts. Some of his pendants can
get pretty large at around 3 inches. I’m using a screen set up on
fire bricks and heat from beneath. I use boric acid and alcohol for
fire scale.
The problem is occasionally some sort of impurity makes its way in
the silver leaving a deep pit about .5 mm wide that won’t buff out.
I bought a new screen. My screen is now fully coated with melted
boric acid from subsequent soldering. I’ve also used a stiff wire
brush in-between soldering. Still occasionally I get an impurity.
I’ve tried supporting the piece on charcoal blocks but have problem
with the piece drooping when reaching solder temperature.
Thanks in advance for any advice.
Rick Copeland
Colorado Springs, Colorado
home.covad.net/~rcopeland/
