Jim,
When ever possible, I prefer to set the meteoric iron rather than
soldering it. This can be by simply surrounding it with a bezel, or
trapping it like channel setting. The laser is the obvious choice
for soldering, but you can use easy silver solder and not totally
destroy the crystalline structure. (Use black flux) This is not
always the case, however, and you may find that the pattern has
weakened or disappeared completely. I have had good success by
putting the piece in an oven at 350 degrees and holding it there for
a day. At the temperatures that you use to fuse layers of metal
together, I’m sure you will eliminate all crystal structure. I have
taken it to a dull red heat and forged some of this material,
changing its shape slightly. I was able to get a crystalline pattern
back.
I have been using the Gibbeon material. I have been able to die
form it, make spheres, set stones in it, carve it, even roll it
through the mill to get a consistent thickness (but not reduce it by
a lot). If you don’t heat it, the pattern will be there no matter
what you do to the surface mechanically. If you sand or file it, for
example, a mild etch will return the pattern. Yes, you can even put
it in a (fresh) sodium bisulfate pickle, and the pattern will emerge,
but you may also get some staining that you may not like. The
nitric/alcohol etch is quite safe, if you treat it like any other
nitric acid etch (we all know the rules here, RIGHT?). And make sure
you use a neutralizing rinse after etching, or you may find that
some acid has become trapped in the pores of the metal and staining
will occur later. I use baking soda and alcohol, followed by an
alcohol rinse.
As far as rust forming on the meteoric iron, it will happen. True,
if you wear the material in a ring, and the ring is not emersed in
salt water, and it is always being rubbed, it will be difficult for a
layer of oxide to form. Inside the holes you’ve drilled for stones,
or the back side of a ring top…well, that’s another story. . Rust
Happens. I like to warm the material slightly, and soak it in a light
oil to impregnate all the pores. After it dries, I apply a light coat
of micro-crystalline wax. If it is an area that will always be
hidden, like the inside of a dome on a ring top, I will apply a thin
coating of Incralac.
As for your 22k and iron mokume ring, you will probably not notice
any rust unless you get it in salt water (like the ocean) or you get
a lot of sweat on it. I have been selling damascus bands by Namu Cho
for many years, and I have only had 1 person who had a problem with
them. I have seen rust appear on many of these, but it is a very easy
cleanup. Just like a gold ring, they will need refinishing
periodically.
Get some meteoric iron and experiment with it.
Doug
Douglas Zaruba
35 N. Market St.
Frederick, MD 21701
301 695-1107
@Douglas_Zaruba
