My welding supply store warns AGAINST using a soapy water solution
to check for leaks on bottled gases, especially oxygen…UNLESS one
is absolutely certain that it is a NON PETROLEUM based soap being
used such as liquid Ivory.
I can’t relay their explanation in detail but the jist of it has to
do with the gases moving into the regulators with such
speed/pressure (especially the oxygen.) that the "friction"
generates enough heat to ignite petroleum residue. They note of
course that this is undesirable since open flame and bottled gases
don’t mix well.
This said I will be the first to admit that I have for years used
"any old liquid soap" and water mixture to test propane connections
and have had no problems. But believing that old dogs can learn new
tricks…sometimes, I have heeded the warning and now use only
non-petroleum based liquid soap. Can’t be too safe with these gas
setups!
(The welding shops also sell bottles of safe solutions for leak
testing .)
Usual disclaimers…
Joe Battle Ground, WA where it’s unseasonably sunny and warm.
solution to check for leaks on bottled gases, especially
oxygen...UNLESS one is absolutely certain that it is a NON
PETROLEUM based soap being used such as liquid Ivory. I can't relay
their explanation in detail but the jist of it has to do with the
gases moving into the regulators with such speed/pressure
(especially the oxygen.) that the "friction" generates enough heat
to ignite petroleum residue. They note of course that this is
undesirable since open flame and bottled gases don't mix well.
The problem with oxygen and petroleum based materials is one of
combusiton. You need oxygen to burn materials. Normally you need a
source of ignition. However, under high pressure (such as an oxygen
cylinder) sufficient pressure will result in combustion without a
spark. Oxygen regulators are specially cleaned of oils in the
manufacturing process for this very reason.
As for the petroleum based soap, I doubt that it makes much
difference because every soap I can think of is made of organic
molecules (carbon, hydrogen and oxygen) which are all combustable.
So any soap you can burn with your torch could be a potential source
of fuel. I would guess that when placing a soap solution on the
outside of a leaking gas fitting any leak forces the soap out; no
leak, no soap goes in either. Keeping all the high pressure
fittings relativley clean is is important. I have always used what
ever soap I have handy. Better to know of and fix a leak than to
leak oxygen into a confined area with an open flame present.
I work with Acetylene torches in an industrial environment. Never
oil or lubricate the threads. IT WILL EXPLODE!
There is a product called SNOOP that you can use if you feel you
need to. Generally a good crescent wrench and a hard pull ( not too
hard) is all you need. Some of the industrial welders I know can hand
tighten the guages without a wrench and get a good seal.
