Okay, so now you know how to engrave metal, so how in heck do you
re-furbish your financial investment in an Onglette? Yes, you must
resurface the metal, or repair the broken point… this is not a
difficult problem. It’s so easy any jeweller of a few years of
experience can do it…you all wanna know how to do it?..So now sit
back and read. If you want my graver-preparation notes/pictures on
this singular topic you can just write to me. This graver process
isn’t hard to do, you must just be darn careful in it’s treatment.
Lets assume that the point of the Onglette is now just “sliding or
scraping” along the metal. This is one indication of a broken
graver point.
To observe the point, look at it through a 10x power loupe. IF you
see a bright and shiny spot right on the point. Well it’s not a point
anymore, you are looking at facet on the graver point… it should
not be there, period!
This could be broken by two or three methods, your face-angle is too
shallow of 45 degrees or more. The second method is that you were
cutting the metal too darn deep and the forward cutting of that
blade got simply worn out. The last thing is that there was some
hidden non-ferrous metal in the gold and oh-oh… broken point! This
can happen to any of us, so don’t feel that it was not your fault…
no one is perfect…got this so far? I use a very cheap long-lasting
Arkansas oil-stone and attempt to sharpen the graver face at
approximately 45 degrees. Please use an oil based semi-liquid to
suspend any metal fragments on the stones surface. IF you don’t, all
of the graver shards of metal and the residue will then get pushed
deeper into the oil-stone. After a few weeks of this, you will
grinding on the metal residue, and not the oil-stone. What kind of
suspension oil do I use?.. Simple, any “10W30” motor-oil, or “3
IN 1” semi-liquid oil…nothing but the cheapest, eh?
Securely grip the graver blade and wooden handle in your hand and
carefully watch for the correct face-angle… remember… *45 degrees
and not anymore, or less. *
Draw the graver across the 3/4 length of the stone… if the stone
is 8 inches in total length, use 6 inches of the stone to correct the
point. Be careful not to allow the oil to mess up your clothing…oil
and t-shirts are not happy campers. This could happen only on the
back-stroke towards you on the graver draw.
After 3-4 draws on the stone, inspect that the point is now
corrected. Now be very careful and make sure that your graver-face is
of equal alignment on either side of the graver. Examine both sides
near the point and align them up equally. Hold the graver at 45
degrees to the oil-stone face and don’t lean the graver towards or
away from you, got this? This is a skilled area to learn. My graver
pictures will identify this “observation” in my notes to you.
Anyone thinks that this is easy, well it could be! Out of 10 on my
difficulty level, graver re-shaping is about a 6>. But once you
observe and learn the methods of fixing your broken point, or
sharpening the graver, it’s then an easier process. Holding the
graver is like doing two things at once. This is a "medium-plus"
skill level.
Reasons for a broken graver point
IF your graver-face is at 60-70 degrees from the 90 degrees
perpendicular, you will break the point so fast you won’t know what
happened. If the graver-face angle is at approx. 30 degrees is almost
like pushing a brick into the metal, nothing is going to happen. You
are going to struggle at every moment and give up in total
frustration. So the "G**olden Mean is to remember the 45 degree
angle rule".
Let’s go over this again, ready? 45 degrees in holding the “graver
to the metal” to be cut, 45 degrees of the graver-face. Same angle to
shaping on the oil-stone (Re: broken point), again holding the same
angle in re-grinding to the graver-face. 45 - 45 - 45 - 45… ad
infinitum.
Gerry Lewy
