Hi, gang, As I’ve commented, recently, I’m in the midst of adding a
jewelry/goldsmithing setup to my existing lapidary workshop, which
is in the basement of the two-family home my fiancee and I are
renting the bottom half of. Although designing and building a
decent, 6-drawer jeweler’s bench wound up being easier than I’d
anticipated, I’m fit to be tied when it comes to my
soldering/annealing setup, and could really use your collective
input…
The “Catch-22” I keep running into stems from the fact that this
basement also contains the oil burner for our heating system and the
two natural gas-fired water heaters for our and our landlady’s
respective water needs. These are about 20’ away from my workspace,
but still within the same room, and all rely on the same ambient air
supply. Last week, a plumber came to estimate the gas line
installation job and expressed concerns about either gas leaking its
way past a check valve into the O2 tank, or O2 backing up into the
gas line, and either way, causing explosions. He then suggested that
the oil and gas heaters, mentioned above, “will turn into Roman
Candles and melt down as surely as Three-Mile Island if you ever
wind up with an oxygen leak” and said I’d have to install more than
$1,000 of protective equipment before he could even begin his own
work, which’ll likely approach that amount, as well. Problem is,
after six months away at jewelers’ school on the other side of the
U.S. from here, I neither have any way to afford this expense, nor
the technical facility to work in a shop, yet, to earn the money to
pay for this!
So, folks, is there another way that any of you have for getting
around such an obstacle? Can I get by, for the time being, by using
one of those butane “Blazer” torches? (Will one of those be both hot
and accurate enough to practice my soldering/repairing skills with,
or is there some other way around this?)
For that matter, is there anyone in the Greater Boston area who has
room for an apprentice in their shop (albeit, one who’s already a
master lapidary)? I’m committed to learning and mastering this
trade, as a means of being better able to translate my jewelry
design ideas from concept to reality, so I could really use a hand,
here.
Many, many thanks,
Doug Turet
Douglas Turet, GJ
Lapidary Artist, Designer & Goldsmith
Turet Design
P.O. Box 162
Arlington, MA 02476
Tel. (617) 325-5328
eFax (928) 222-0815
anotherbrightidea@hotmail.com
We always do the
