While working at the 3M products/demonstration tables at the recent
SNAG Conference in St. Petersburg I talked with many attendees about
their use of the 3M Radial Bristle Discs. One problem we discovered
is quite common. Many artists and students were using one disc at
time mounted on their mandrel. These discs are intended to be stacked
together to make a high performance brush. I would suggest for the
9/16" and 3/4" size that stacking six discs together will make the
best performing brush. For the 1" size stacking at least three discs
together is best. Also, when using these high performance brushes a
light touch on the surface of your work piece will bring you the most
satisfactory results and the longest life. The majority of the
artists who had been stacking the discs love using these little
bristle brushes. 3M is proud to support SNAG … see you in Cleveland
next year !!!
Rick Pihl - Product Development Specialist - 3M Abrasive Systems
Division
R i c k P i h l
3M Abrasive Systems Division
3M Center, Bldg 251-3A-05
St. Paul, MN 55144-1000
Office : 651-733-0824
FAX : 651-733-6376
Email : @rmpihl1
