I have made several dozen of this type of ring during the course of
my career.
Some with collets similar to Leonid’s, others with U shaped collets,
with crown collets, wire collets and pave with a gallery underside.
Typically, they are not difficult to make, rather just a lot of
repetitive work that becomes very boring, very soon.
Leonid is correct in saying that a printed and cast ring cannot be
finished off as well as a hand assembled ring.
This is simply because all the methods of finishing such as
mechanical polishing, tumbling, electro polishing and bombing simply
do not match the quality of hand polishing on a polishing lathe.
Hand finishing each individual component before soldering takes
place makes for a good overall finish, and is pretty much the golden
rule for all high end jewellery.
What is incorrect however, is suggesting that cast components cannot
match the handmade components, both in strength and density.
Most certainly cast components can be of inferior quality but in
high end casting workshops, it is virtually impossible to discern a
difference.
Under a microscope maybe but to all and intents and purposes, more
than strong enough for day to day wear.
Estimating casting shrinkage,(typically at less than 3%) is quite
possible and the subsequent soldering operations can be done as
delicately as any handmade component.
Those skills are widely available amongst casters and goldsmiths.
However, this type of ring is usually made in high carat metals,
simply because the labor cost justify expensive material and that the
metal is able to keep its finished pre polish better than low
caratage metals.
One reason I suspect the Leonid has no high res picture of his
finished model, is that a ring like this will typically have more than
forty solder operations.
And since his model is made in silver, it will not retain it’s pre
finish polish and the solder joints will show pitting which would be
quite clear in a detailed photo.
Nevertheless, if one had to design a ring in CAD and then cast the
individual components, or hand make each individual component, the
resultant two rings would be identical to all intents and purposes.
This is simply because the subsequent hand operations would reduce
the precision that CAD introduces in the model.
Once finished and set, both would look handmade and
indistinguishable from each other.
meevis.com
