I’m trying to melt 18K yellow gold (United 790 alloy, consisting of 53% Cu, 44% Ag, 3% Zn and maybe a trace of some ‘proprietary’ metals). On my first attempt I treated it very similar to the Stirling silver I’m used to and the ingot started cracking like crazy, so I read a bunch of different resources and threads on the matter and remelted and started working the bar according to this process:
-Melt with a reducing flame, stir once molten with a graphite rod for 45 seconds or so, then pour into iron ingot mold (4.5mm thick) pre heated to 300C. Quenched as soon as I could get it out of the mold.
-Sprayed with firescoff and annealed for 20 minuted in a electric furnace set to 704C, as per the spec sheet, quenched in water pretty much immediately. Here I’ve seen some conflicting info, but I figured annealing immediately couldn’t hurt, especially since it probably took me a minute or so to actually remove the ingot from the mold. I’ve also read about quenching in alcohol, but this is a small bar (~20g) so I doubt that’s the issue. I then pickled the bar.
-Forged the bar to ~3.5mm, annealed again with the same process, forged again down to 2.5mm. At this point there were some small cracks on the edges which I filed, and the metal had some slight patches that had a more coppery rose like color.
-Annealed again with same process, then went to the rolling mill. Rolled to 2.25mm, and annealed again.
It is at this thickness that I noticed some pretty large patches with a coppery color, I would compare it to Russian 14K, and significant surface cracks, most of the cracks in the coppery areas. They are not yet super deep so I filed them all out, but sanding the whole thing down gently, the rose color patches stay, and I’m certain it will continue to crack if I try to roll further. Besides the fact that the color differences already make it unusable.
My first attempt I simply torch annealed and less often, and went to the mill straight away, result was the same, just happened earlier.
The coppery patches to me indicate that the issue is likely with my casting, but what should I do differently? I’m thinking of keeping it liquid for less time, but otherwise I really don’t know what else to try.
