Hello everyone. I am still having cracking problems with 18k Yellow gold casting.
Problems: multiple cracked lines but rest of piece is solidify and flexible.
Tree would consist of 90pc of jewelry , thick items on top and thin on bottom . Sprue shouldn’t be a problem because 18k white would come out with success. I don’t believe its contaminated alloy problem because 70% items are cracking and 30% good with gold flexibility all mixed on different areas of the tree.
18k white, 14k white& yellow, silver casting successful.
My casting spec 18k Yellow:
-using a closed vacuum & pressure casting machine with Argon gas.
-mold wax injection
-3 x 7 inch tree , mixed with men ring (top) , earrings, pendants
-1200F Flask
-cast with pure 99.99kt and 18k yellow alloy
- purchased alloy and homemade alloy with same outcome.
-Vacuum - 30hg 4min
-Pressure -2.5kg 15 seconds
-Have tried quenched after 10min / No quenching with same results
-air cooled 1hr with same cracked results
-our thermocouple type K keeps burning out so we just eyeball our gold melting temperature and press pour
Inspecting the tree after cool down with our microscope and it looks like the cracked lines are SHINY , so I’m assuming it cracked after cool down.
Not sure if my temperature , vacuum , or pressure is off . Please help me.
Thank you.
