I have a custom peice that I am working on that combines 14kY and a
high carbon stainlees steel (17-4).
I would like very much to solder the peices together rather than
using a cold joint technique like rivets. However, the flux is
causing the stainlees to oxidize and not allowing the solder to
flow.
Does anyone have a recommendation as to how to solve this problem?
