11 years ago I made a 2 piece wedding ring using 14K Palladium white gold casting grain from Umicore. The customer asked me to resize them from a 5 to a 6.5 Yesterday while trying to open the band; the band fractured. Initially I cursed thinking, “Well perfect end to 2020” and decided it was a good time to open up the bottle of Rum I was gifted at Christmas. Now I’m thinking the fracture may have been a blessing… because… maybe I can make sure the ring does fracture… when my customer is wearing it.
I don’t work with Palladium White Gold very often (Clearly)… and I need some help… so that I don’t mess this up any further.
(1) What type of 14k white solder should I use. Stuller has a 14k White “Color match” solder… but, Stuller also says “Color match is a solder that formulated to specifically match Stuller products. Regular solder would work for the standard karat being purchased.”
(2) Annealing? I want to anneal both rings after I bring enlarge the rings from size 5 to 6.5 I’m worried about that Diamond. Should I use my kiln or torch to bring the rings to annealing temperature?
