This gem-stone setting 4-day class is aptly called…“To Bead, or not
to Bead!” this name is used to describe this very special setting
class. I will be delving into the “Advanced Level” of
Diamond-Setting, Pave or “Bright-cutting” & extensively using
Onglette gravers. As this program is so specialized, I will explain &
demonstrate how to cut an Azure-pattern under the setting. Included
will be ‘How to add’ a round stone after your own Channel Setting
project has been completed! For each student, there will be a set of
3, gravers (shaped by myself).
Now all you do is to use them & no further grinding. This class will
be held in Grand Haven, Michigan. November 13-14-15-16. Please
contact Julie Sanford @ 1-616-607-2470 or register on-line, as well
as http://www.ganoksin.com/gnkurl/ep80fu
Gerry Lewy
