I make (so-called) Damascus steel jewelry which includes bracelets
and pendants as well as rings. This is from pattern welded carbon
steel that I make myself. I refer to it as Damascus because it gives
the customer a starting point for understanding what it is. Then if
someone seems interested in knowing more I’ll explain that it’s
modern pattern welded steel. Whether or not it is really suitable
for jewelry is a matter of opinion, surprisingly, rings are fine,
they don’t rust any more than a steel tool that is handled constantly
will rust in your hands. There may be some people with a body
chemistry or lifestyle where rings would rust, but so far no
complaints and I’ve been making them for several years. Jewelry that
isn’t worn constantly is another issue. If its left somewhere damp,
or with something corrosive on it, which could be a variety of things
from daily life, like food spatters or cleaning agents, you may find
rust. Again, think of a steel tool that might sit somewhere unused.
If it was something you valued you might take care to keep it safe
and dry and maybe put a little oil on it as a precaution when not in
use. I have flush set small stones into it in an annealed state. I
have soldered it, but I’m aware that the solder joint may corrode, so
I don’t make anything soldered for customers unless they understand
its experimental. The tool steels used in modern Damascus are not fun
to cut or drill and its messy. To make jewelry from it, it would help
to have some experience as a blacksmith and/or machinist as well as a
jeweler.
I use Stainless Steel “Damascus” as well which of course does not
rust. Personally I think it lacks the life and also the myriad of
pattens one can achieve with carbon steel.
Celeste
