Winter storage
I have a she shed which is unheated. As winter gets closer i was wondering if i should put my files, wires, sheet metal and pliers etc into my garage which if heated…thanks
Welcome to the forum! Check out this thread. It’s a very similar question.
Jeff
An alternative is a plastic bin with some silica gel (dehydrator) in it. It is condensation, not cold per se, that inflicts rust. If things stay truly cold, the air is dry. Temperature cycles are the problem. Heated is better
