Mo betta heat! Sterling silver melts at 1640 F. Hard solder flows
between 1375 and 1490 depending on the manufacturer.
For a bezel, you have a tiny area to solder your bezel together.
Lots of heat thrown at a tiny mass. You are probably using fine
silver bezel which has a higher melting temperature, but no matter.
It’s still a lot of heat directed at a small area which is thin.
Now you are soldering the bezel to a large amount of silver. I don’t
know your dimensions or mass of the metal, but here is the analogy.
Think of your stove. Take a tiny sauce pan that holds 1/4 cup of
water and put it on the stove and turn the heat up to high. If you
have gas or electric, won’t matter. In a few minutes that water will
be boiling away.
Now go get a huge stock pot, fill it with water and do the same
thing, but turn the heat down low. It will sit there and sit there
and do nothing. The mass of what you are heating is exceeding the
thermal capacity of the water. You need more heat to boil the water
and to match the mass. It will take longer even if your stove is on
high, but eventually it will get there.
For soldering a bezel, solder will flow towards heat. If your torch
is above the bezel and your metal and the flame pointing down, the
tiny mass in the bezel will heat up first and the solder will start
climbing up the bezel because solder flows to the hottest point.
If you take some crosslock tweezers (cheap push for mine here), hold
one end of your metal and bring your torch UNDERNEATH your highly
fluxed silver piece, your base metal (I call it parent) will heat up,
solder will flow downwards and if your fit is good between your bezel
and your parent metal, voila! The solder will run its course and it
will know exactly what to do and where to go.
Where to put those chips? Well, if you are setting a stone and
completely removing all the surrounding metal, put the chips on the
outside of the bezel. Remember, always solder so clean up is easy. IF
you have a highly decorated exterior piece, you will want to put the
chips on the inside.
How many chips? Depends on the size of the piece. For an area of 1
inch by 1 inch, I would use five really tiny chips. If it needs more,
then use more. Sometimes if you just clean the piece up and use the
existing solder you won’t need any more.
Size of solder chips? Tiny, itty, bitty, really, really tiny. Think
of a fire in a fireplace. You have a tiny glowing ember. IF you put a
small stick in the fire, the ember will catch and the stick will
burn. Now, go put a giant oak log on the ember. Will it catch and
burn? NO. You need to stoke that fire, add tiny pieces until it can
take a larger piece.
Remember, you don’t have to solder that bezel all at once. Just TACK
IT with a few tiny pieces so it won’t move. Clean it up, flux and go
after it again. You will be amazed how little you need.
When I teach soldering, I snip a piece in my hand and show it to my
students. They are in shock that such a tiny piece will work.
Exercise for soldering.
Here is a quick exercise for soldering.
Simple band ring. We’ve all made one but bear with me here.
Form the band, say 18 sterling ga, 6mm wide x 65 mm long.
make a good fit so no light is coming through. We don’t’ want
“gaposis”.
Flux your piece and make the ring stand up with the seam side
down.
cut a tiny, and I mean one tiny piece of hard solder. How tiny?
Take your thumbs and index finger and bring them together, index to
index and thumb to thumb and create a negative space in between.
Close the gap with your fingers until just a tiny spec of light shows
through. (those with long finger nails might have a tough time). That
little light shining through should be the size of your solder chip.
load your chip onto the center of the seam. Allow your flux to
dry.
Now, take your flame and aim it just to the right of the seam.
Now here is my little saying. “Go around and around and take a little
vacation”. That means move your flame on the band ring around
clockwise, and then counter clockwise and when you reach the seam,
stay there for a bit. Keep repeating and pretty soon, your solder
will melt right into the seam.
By doing this, you have allowed the metal to heat up evenly, while
the center seam receives additional heat. The surrounding heat is
driven down to the seam and the solder has nothing more to do except
to flow.
Karen Christians
Waltham, MA
http://www.cleverwerx.com
