"I mean what do South Carolinians with gas stoves do?’ - the way it
was explained to me was that the problem is the pressure. The gas
that is piped into my house for heat is low pressure; the gas in the
portable propane tank for my torch is high pressure. It is the high
pressure gas I was told I could not run into the house. And here it
is not plumbers who run the piping, but the gas companies. So since
they had piped the house with the propane we use for heat, I had
"ass"umed that they could just tie me into that. Hah! They said that
was low pressure and would not run my torch correctly. So then I
asked about setting up a permanent pipe that would let the small tank
be outside and connect to the pipe, and my torch would connect to the
pipe on the inside. No, they said can’t do that in SC.
“I’d double check that. Its my understanding from the local fire
marshal (most local codes are based on the national) that the tanks
cannot be indoors, period. In use or storage matters not.” Probably
true, but as I solder in my studio, it would be rather difficult to
actually USE the tank if it isn’t in reach of the torch! Absolutely
no idea how anyone else handles this… it has me a bit flummoxed,
to say the least. I did check with my insurance agent, and he said
just bring it in and out. So that is what I do. Good for the muscles
I suppose.
Beth Wicker
Three Cats and a Dog Design Studio
http://www.bethwicker.com
http://bethwicker.ganoksin.com/blogs/
