Goldsmithing is NOT just working with gold, it is working with metal
to create jewelry, for which gold was traditionally used.
Silversmithing is NOT just working with silver, it is working with
metal to create hollow ware and flatware & such, for which silver was
traditionally used (OK, just for the fancy stuff).
silversmithing is sheet metal and wire work, where goldsmithing is sculpture. I made that up for myself, but it's pretty accurate.
Obviously made up himself, certainly not accurate.
Beautiful and sculptural work can be created in any metal and in
either discipline. So can simple “sheet metal and wire work”.
For those who work mainly in silver & were reasonably put off by
what appeared to be (and perhaps was, to be honest I’m a bit confused
by his stance) a statement that all work done in silver is just wire
and sheet and can’t be scuptural, created from scratch, beautifully
crafted, etc, again shows the assumptions that the term he used,
“silversmithing” refers to all work done in silver. Those who work in
these disciplines need to understand the terminology. When you start
to learn to make jewelry with metal, torch & hammer, you don’t take a
silversmithing class, you take a goldsmithing class. When you take
that class, you likely don’t even start out by working with silver,
but perhaps nickel (or other less expensive metals), but the class
isn’t called “intro to nickelsmithing”. A goldsmith at a jewelry
shop might also make you something in platinum, but that doesn’t mean
he’s also a “platinumsmith”.
These terms are for the disciplines, not the materials. And, OF
COURSE beautiful & sculptural things can be created from silver! To
say otherwise is ridiculous.
Lisa
Designs by Lisa Gallagher
