Hello Razine,
I have a picture of what this looks like finished but not an
illustration of the steps. If you are interested in seeing the
finished look send me your e-mail address and I can send the picture
off the list.
Grace
Hello Razine,
off the list.
Grace
Almost all the necklaces I have made that incorporate stringing have
a transition point, because I like the back third to be a series of
beaded wrapped-loop elements alternating with soldered jump rings
(which I admit I purchase from Rio). This makes a strong, flexible
necklace that can incorporate the S clasps I make. I almost always
use S clasps, in part because they makes a symmetrical adjustment of
length possible.
I prefer to hide the final loop of the Softflex (which I too like
better than other brands), since I find this more objectionable than
the crimp itself. And I donât use âthreadâ because I was taught that
itâs incompatible with metal beads.
I hope this description of what I do is intelligible, since I donât
have a camera:
I incorporate the crimps into the beaded design, usually as if
they are spacers. Using other small metal beads helps, as does the
fact that the crimps are actually fairly far from the clasp. I always
use the best crimps I can buy, and shape them gently (the new Magical
pliers sound awesome), and I sometimes use two short crimps, with
other beads between them, rather than one longer oneâless obtrusive.
I end with two or three (non-crimp) beads after the crimp,
running a piece of 24 g. wire through the Softflex loop, before
running the Softflex back through the beads to the crimp.
I make a tiny wrapped loop on one end of the wire, over the
Softflex loop, and gently squash the former. I then string a bead
over the squashed loopâI have collected beads with large enough
holes for this purpose, but even small metal beads usually work, and
I sometimes make a wire âbeadâ for this purpose. However, the bead
needs to be long enough to hide both the tiny bit of Softflex and the
squashed loop, so I always consider how this will work with my
design.
I use the other end of the wire to make a wrapped loop over a
soldered jump ring. This wrapped loop appears to âgrowâ directly out
of the stringing. The jump ring becomes the first âclasp stationâ (is
there another term for this?)âone which enables the necklace to be
worn approximately choker-length. The additional jump rings, and
connecting beaded wrapped-loop elements, act as matching dangles down
the back at this length (I once had someone with a beautiful back,
who loves to show it off, order a necklace with these dangles made
purposefully quite long). The jump rings also serve as stations for
wearing the necklace at longer lengths. I always end this series with
a small dangle, often on a spiral head pin.
Hope this dissertation helps someone!
Lisa Orlando
Albion, CA, USA
Hi,
I have a picture of what this looks like finished but not an illustration of the steps. If you are interested in seeing the finished look send me your e-mail address and I can send the picture off the list.
I also would like to see your finished result.
Liz
