Why won’t these dials go on???
Hi,
they “should” just push right on, over that quick change collet holder head…
and that little black o- ring protrudes ever so slightly, and provides a bit of grip…
they should line up with the peg…
“what” is causing the dial not to go on…?…hole to small…?
julie
I’ve got the GRS version of this holder, which isn’t much help.
I can’t tell from the image what the problem is. I looked this holder up online and at all the pictures. All of the parts should easily fit together. Like Julie says, can you give us some more clues what the problem is?
Thanks!
Jeff
Hi,
yes, i have the older dual angle sharpening system, but i have used the apex system, during a class at the GRS training center.
the colored duals just pop on and off easily…
does your collet holder head fit theu the center hole in the dial…is it getting hung up somehow?
julie
