First of all I want to thank everyone who gave me such helpful and
valuableadvice, both on-line and off-line. I truly appreciate it
very much.
I did my first vacuum casting and wish I could say that it was a
success. Unfortunately I had the dreaded blow out—a term that
meant nothingto me until I experienced it. Fortunately I had only
burned out one flask in order to see how it would turn out. Good
thing, as I only lost onewax model.
I wasn’t too concerned even though the blowout totally melted the
plastic tubing under the casting table, and the silver was fused to
it–an ugly mess. I had some extra tubing, and figured I would cut
off theruined piece, replace it with a fresh piece. That was easily
done. Next I noticed that the in-line filters were clogged with
investment, so decided that they needed to be replaced. Fortunately
they stoppedthe investment from entering the pump, but just to be on
the safe side I will drain the oil, and replace it with fresh.
Now for the bad news. I called Rio, and learned to my dismay that
they no longer are able to get the size In-line filters I needed,
and that all the newer vacuums now have smaller diameter tubing and
In-line filters. I spoke at length with their very helpful
technicians and it developed that the only course of action was for
me to ship them the vacuum table and that they would replace the
larger diameter hoses and in-line filters with the newer smaller
ones. As the brass barbed connectors on the pump, and the bell jar,
have the larger, permanently installed brass connectors, they will
arrange some adapters so that they will accommodate their larger
size.
Now for some good news. I did a search of the archives to find out
the causes of blow-outs, as I had done everything according to the
book. Properly measured, mixed, and invested the investment, careful
measurements of metal and an 8 hour burnout with a nice cleanlook to
the investment in the flask.
However, the one thing I was unaware of, and which was the cause of
the blow-out was that there needed to be at least 1" or more of
investment above the model. I was using a small flask, and after I
scooped out some of the investment to get a good seal, it was much
too thin resulting in a blow-out.
It was a lesson I shall never forget—as well as an expensive one.
The vacuum table will be shipped to Rio on Monday, and I shall
eagerly await its return.
When next I try vacuum casting it will be with much taller flasks,
so that I am sure there is enough investment between the top and the
model, something I was totally unaware of, and never thought to
inquire about.
Alma
