Have been sitting in background for some time with this making a
band to fit next to an engagement ring. Long Long ago in the
land of learning this trade from some old timers, ( nitric acid
in a jar with thin rolled scrap cut small to refine the gold. All
done on the roof tops so it would not eat you and the venting
system up. It will give you three 9’s if pressed for time…)
back to the band, we used a two part mixture that dentist us for
making bridges, acrylic stuff, some is clear and some is pink,
also it is used at your friendly neighborhood beauticians to make
fake finger nails. I think the name is: Monomer L2000 and NP 400
Powder. So what you do is clean ring, spray mold release on
mandrel, slide ring up on mandrel tight, In some cases you may
have had to put some pink sprue wax in the bridge work, or air
lines of some styles to stop the acrylic from flowing into a
space that would not let the two separate. Then use a strip of
clay from a toy store, not play dough, just like when you were a
kid put some in your hand a roll it on the table into a thick
worm or snake use the clay and make a dam around the
mandrel,
about 1/8 to 1/4 inch wider than the band is going to be, so
looking at the mandrel you would have a clay dam wrapped
around
the mandrel, a space, which you are going to fill with acrylic,
then the engagement ring. OK ! So the next thing you do is Mix
the two part acrylic stuff, and you have to be fast because it
sets up quick, have a friend or use a mandrel holder so you can
turn the mandrel as you pour acrylic in the space between the
ring and the clay dam, fill it up keep turning and bingo it sets
up hard… Let set for about 30 min. or so. Pull clay off, Save
for next time, slip ring off and separate acrylic from ring. Then
you just start to finish it as you would a poorly cast ring with
flashing and mold marks, it works like soft metal, use a file and
you can use sand paper and if I remember rubber wheels and the
polishing machine. You can also put it in the boil out and use
the steam to clean it. When finished you may have to use some hot
wax for surface as it may have a pit or two but no big deal. It
sounds hard but it isn’t and it opens the door for some other
possibilities as you let you artistic minds roll. In fact it is
kind of fun to do. I like the smell of it, as I am just an old
hippy. This time of year it gets you up from the bench to get a
break and do some moving around… Learned this one, lets see
back in the 80’s from Bob and he got it from the late 40’s early
50’s…
Hope you can understand this as I have written it but if not let
know and we will try a new approach.
JB…
