What I mean is that putting feeler gauges or pieces of paper in
between rollers to check their alignment is just plain silly.
Often, yes. It’s useful, though, for some things, including
detecting the degree to which the rolls are compressed slightly in
the middle rather than flat. (see below…)
Your average under ten years old mill will be just fine with a
visual.
Of course. Who said I was talking about new mills? My own favorite
flat hand rolling mill was made somewhere around 1920, I think. We’ve
got another, virtually the same, where I work, as well as an old as
the hills power mill there too. None of these three have actual
springs holding up the upper roll. Instead, they have a strap
attached to the bearing, that holds the roll amost up in contact with
the bearing, but only barely. You can’t adjust the gap on these just
visually. You have to put a slight load on them.
I grant you that even then, you’re right that you don’t need feeler
guages. If you roll a piece of sheet, and it curves to the right or
left, adjust the top gears accordingly to fix. Don’t even have to
look at the rolls. It might take a couple tries to home in on the
closest adjustment, and with old mills where there’s some wear on the
rolls, you might have to take almost perfect instead of absolutely
perfect.
bottom line is that there are a number of ways to adjust a mill.
Seat of the pants by seeing what’s not going straight, or visually,
or with feeler guages, or who knows what all else.
By the way, one other point that nobody’s made yet in this thread is
that sometimes, you may intentionally want the mill to be
misadjusted. If one side of the rolls is tighter than the other, the
metal rolled through it will curve away from the tight side. Bending
a piece of sheet metal to the side, in the plane of the sheet, is
difficult. You can do it with hammers, forging one edge and side to
stretch it, but not the other, so it curves. If it’s a narrow strip
of thicker guage metal, you can sometimes figure out how to get it to
just bend without buckling anyway, but for wider or thinner sheet,
the easiest way is with the rolling mill adjusted tighter on one
side. How much tighter you do experimentally with a piece of scrap.
Oh, and if you’re starting off with a properly adjusted mill, use a
marker to mark the proper position of the gears so that when you’re
done, it’s easy to put them back where they were.
Why would you do it this way? Well, consider how you’d make a sheet
metal blank that will bend around into a cone shape, rather than a
cylindar, such as you might wish to do for, say, a neckpiece made of
wider sheet metal. You can, of course, saw out the arc shaped blank
from wider sheet, but for something larger like this, that needs a
lot more metal. Doing it with the mill, if you get it right, you can
make that preform or blank with no waste…
Peter
