I own a kiln and a Smith Little Torch. I want to try enameling beads–can I mount my Little Torch to the bench and use it? Will the rosette tip be the tip of choice? Should I just spring for a Hothead?
What method of firing beads is your favorite? Kiln or torch?
Secondly, which Thompson enamel and what form (wet or dry) do you use to make very fine lines and what is your implement of choice-nib, brush, toothpick or what-have-you?
