Can someone please explain to me the difference between vermeil
and gold plate? I know that vermeil has a thicker plating of
gold than gold plate, but I need a little more If I
have a ring with vermeil areas, will the vermeil hold up well, or
will the gold wear off easily?
My thanks to anyone who can shed a little light on this subject.
Lindsey, Vermeil refers to gold plating over silver. It has
nothing to do with the thickness of the plate, just the fact that
it is gold over silver. Joel
Ever wish you could take back an email. I looked up the
following after sending a message based on my memory.
I’m on my way to the store for some Ginko Biloba.
The following is excerpted from an sheet from Red
Sky:
Electroplating is regulated by the Federal Trade
Commission. The following has been gathered
from their publication, Code of Federal Regulations Title
16 - Commercial Practices part 23 (January 1, 1994):
Gold Electroplate - Electrolytic plating of 24 karat
minimum fineness, and a minimum thickness of 7 microns may
legally be marked or described as gold electroplate.
Heavy Gold Electroplate - Electrolytic plating of 24 karat
minimum fineness, and minimum thickness of 100 microns may
legally be marked or described as heavy gold electroplate.
Gold Flash or Gold Wash - Electrolytic plating of not less
than 10 karat minimum fineness and a thickness of less than
7 microns may only legally be marked or described as gold
flash or gold wash.
Vermeil (Pronounced VER-MAY)) - The Jewelers Vigilance
Committee, Inc., has recommended that the Federal Trade
Commission establish that vermeil meet the following
requirements:
Sterling silver jewelry that has an electrolytic plating
of 24 karat minimum fineness and a minimum thickness of 120
microns. A diffusion barrier against tarnish (typically
nickel) not to exceed 50 microns is also acceptable.
As well as being a thicker coating of gold (at least it s’posed
to be ) than regular plating, there is no nickel involved in
this process …the silver will oxidise underneath, so
customers will (god forbid ) have to clean the pieces once on a
while (tell 'em not to use a polishing cloth!), but for those
who are allergic to nickel it means that if it is an item that
they would wear against the skin they are not restricted to
purchasing solid gold pieces which they perhaps can ill
afford…and which might suit them better than silver . Happy
Holidays to everyone Alison
I have another question along this line. I wear my grandmother’s
wedding ring which was made for her by her first husband out of
nickels. When I got the ring (over 30 years ago now), I went to one of
our local jewellers and had it “rolled” in white gold. Can anyone
tell me which process this might have been? The gold has worn off just
a little in the inside, but the outside continues to look as though the
ring is solid white gold.
Jan
Jan MacLellan
Mountain Gems Ltd.
4611 Hastings Street, Burnaby, BC Canada
V5C 2K6
Does anyone know the history of vermeil? What are the pro’s and con’s
(if any) of working with it, or owning it? Is the process of creating
it, basically plating? Also, I heard a long time ago that if you
combine silver and gold the gold molecules will eventually drift and
be “absorbed” by the silver. Eventually you no longer see the gold. Is
this true? Thanks everyone! -Iris in San Francisco
