When I'm using it I can barely see an outline of the piece I'm working on. Any suggestions, different light maybe or different light position?
You’ll never see all that well through those tiny spinning slits. You
don’t need to. All you need to see is the surface itself which you’re
polishing, to be sure you’re lapping in the right plane and to be
able to see how much you’re cutting off that surface. Use a good
bright lightbulb (I use standard 100 watt bulbs, but have decent air
flow in the area, so it doesn’t get too hot. Depending on your setup
and preferences, you might need smaller, or even higher wattage. Now,
with the lap not operating, position one of the slits at the bottom
of the laps rotational path, the area where you work. Hold a mirror
or bright shiny metal surface in contact with the lap under the slit.
Position the lamp somewhere in line with the slit, with your head in
it’s normal or most comfortable working position, so that you see a
reflection of the light bulb itself in the visible small bit of that
shiny metal surface. When you’re working, you’re depending on the
fact that the surface being lapped is bright enough and reflective
enough to directly reflect that light from the bulb back to your eye.
If the bulb is not postioned for that direct bright reflection,
you’ll see almost nothing. The lamp can be positioned quite close to
the top rotating surface of the lap, since you’re working on the
underside. For me, it’s barely below the center spindle of the
machine most of the time. Your working postion will determine what’s
best for you. Also, note that since the lap is thinnest near the
edges, more light gets in there (light can get to the metal surface
over a wider angle), so you may get a better visibility if you work
just near the outside perimeter of the lap.
Peter
