Where do you start to learn to use lathes and mills in fabrication?
Especially if you are interested in using 'em with CNC? Belinda
Hi Belinda,
Where do you start to learn to use lathes and mills in fabrication? Especially if you are interested in using 'em with CNC
One of the best sources is a local community college. Check to see
if they have a Metal Working Technology for similar) dept. Another
source of info is the library. If your library doesn’t have books on
the subject, try lindsaybks.com . Lindsay Books publishes older out
of print books for metal working. Some of the books were written a
looong time ago, but the principals of how lathes & mills work are
still the same. The only differences are improvements in materials &
techniques.
When you get into CNC, there are courses available from software &
equipment mfgrs & GIA & others.
Dave
