I got a little airbrush air compressor for nothing at a garage sale
and I am trying to think of how it could be used in my studio.
One thought I had was to make a paste solder applicator for the
syringes since the paste solder i use is hard to depress for my
hands. Can anyone offer me the instructions how to set this up?
Also, any other ideas for this little compressor?
Thanks,
Margaret
Note From Ganoksin Staff:
Looking for an air compressor for your jewelry projects? We recommend:
Hi Margaret:
I use one to pressurize my wax injector. I’ve got it on a foot-
activated switch, so it only comes on when I stomp on it. I’ve got a
very small hole in the airline, so it bleeds down to nothing in about
30 seconds. In use, I can vary the pressure on the injector for each
mold, without having to use my hands. I just stomp on the switch,
pump it up to whatever pressure I need, and shoot the mold. By the
time I’ve got the next one ready, it’s dropped below where I need it,
so I just pump it up to wherever, and go again. Very handy.
Regards,
Brian Meek.
brian - foot switch activated wax injector pump, that is a great idea
would it be too much trouble for you if i asked you for a part number
or source on that switch i am using a pump like you use it would be
fabulous to up grade
goo
I use a small compressor to blow a stream of air across sheet silver
when I am piercing it with a saw; keeps the filings away from the
line which I am trying to follow. I fed a small piece of surgical
tubing from the compressor to a section of brass tubing which is in
turn held by a machinists height gauge thus allowing me to direct
the air stream. The compressor itself is powered on and off at will
by a foot actuated switch. Work great.
Jim
Hi Goo:
I frankensteined a dead foredom foot pedal. Ripped the guts out,
replaced them with a momentary on switch. I burned it out at a
workshop at school last month, so I’m re-doing it with a better
switch. I can take pix if you’d like. You can also get momentary-on
footswitches from places like Enco and MSC too. Woodworkers like
them for their drill-presses & etc.
Cheers-
Brian.
