I have some large Bali Beads which are made from two bead caps
soldered together at their bases.
If I can split the bead into the two caps, then I have a use for the
2 bead caps. It concerns me that applying heat to the joint may
melt/disfigure/displace the granuals of silver decoration on the
bead.
What advice and suggestions do you have for me in separating these
beads.
Thanks,
Chris
Bristlecone
