Hi Sam,
Is it OK to wet sand with 600 grit sandpaper by hand then buff on a
muslin wheel?
Yes, I padded the setting with some cardboard from a cereal box. The
problem came from a burr on the inside of the bezel from where I
soldered it together. It was a sawtooth wire bezel. In setting the
stone, the burr must have put too much pressure on that side.
I think what happened is that in trying to solder the shank on, I
got too much heat on the weld and the bezel joint moved and created a
burr (probably some melted solder). Oh well, it was a good
educational experience.
The stone is stabilized and it has a dark hard waxy backing. I
purchased the stones, so I don’t know anything more about them. This
stone was particularly thin, but has a beautiful pattern
nonetheless.
Thanks so much for sharing your knowledge. I’m off to buy some
epoxy.
Tracy
Tracy’s Treasures
