Jim,
I’ve been using a small (Gemstone, Simi Valley CA) vibratory
tumbler for about 7 years. It’s used mainly for burnishing fine
& sterling silver chains, however, I’ve tumbled cast & flat
pieces with very good results. Also tumbled gold & gold filled
stuff with no problems. On occasion I tumble a piece that has a
stone/s in it, as long as the stone is harder than steel & not
porus.
The bowl is 8" in diameter & about 4" deep. I have 7.5 lbs of
assorted shapes of carbon steel shot in it, (about 1/2 full). To
this I add a pinc h of burnishing soap & about 1 oz (shot glass
full) of household ammonia; toss in the items to be burnished &
turn it on. Actually, you can use an y very low sudsing soap in
place of the burnishing soap.
Chains take about 1/2 hour, larger pieces take longer but I’ve
never had to let them in over 2 hours. Time depends on how much
of the piece remains imbedded in the shot as the tumbler is
running. Best results are achieved when the shot & items maintain
a rolling churning action. Any time the piece is submerged in the
shot it’s being burnished wherever the shot contacts it.
When the shot looses its shine I dump it into a food strainer
(sorta like a screen) & wash it off with warm water. Dump it on a
bath towel & spread i t around to dry it a little, then back in
the tumbler. Add a shot of ammoni a, a pinch of burnishing soap,
put the lid on tight & run the tumbler for a few minutes. This
coats the shot with ammonia & burnishing soap; helps ke ep the
rust down. Oh, be sure to clean the tumbler bowl out before
putting the clean shot back in. If the tumbler sits a day or two
between jobs, you may want to add another shot of ammonia, a
little experience will help here. If the shot looks really
grungy, I add about 1/4 cup of Draino or lye, a cup of water &
let the tumbler run for 1/2 hour, then do the warm water rinse &
finish as above. I’ve been using the same 7.5 lbs of carbon steel
shot for the whole time. Rust does not seem to be a problem as
long as the lid is put on tightly when not using the tumbler.
Stainless shot would be better if you can afford it. Thunderbird
has it for about $10.00/lb, carbon steel is about $5.00/lb.
This system works well for a low volume operation. For larger
volume, a larger tumbler with a flow through system would reduce
some of the housekeeping chores. Its important to remember that
tumbling with steel shot just burnishes th e piece, it will not
remove scratches, dings or dents. Pieces will come out somewhat
harder than they went in, they’ve been work hardened by the myri
ad impacts of the shot. I’ve never tested a piece, so I don’t
know how much harder it gets.
Tumbling sure’s a lot easier than hand polishing.
Dave
