I also trumble lots of chains (other things too). I use a small
vibratory tumbler with about 7#s of assorted shapes of shot.
Dave - I use a rotating tumbler with steel shot (asst. shapes and
sizes), would that make a difference? I will certainly give it a
try. Also, the burnishing soap was purchased and is specified for
silver and another for gold. I was told to use about 1 tablespoon.
It really foams up, but has not overflowed the tumbler. Any
suggestions? It seemed to do the trick on an oxydized silver piece
piece I did. I have not finished my gold piece yet… still working
on my clasp.
I use a rotating tumbler with steel shot (asst. shapes and sizes),
Probably not, It’ll just take longer. Rotary tumblers are slower than
vibratory tumblers.
Also, the burnishing soap was purchased and is specified for silver
and another for gold. I was told to use about 1 tablespoon. It
The main purpose of the burnishing soap is to act as a lubricant
between the shot & the items in the tumbler. I’m not sure a seperate
burnishing soap is needed for gold (unless you’re doing industrial
quantities). I’ve used the same soap for both gold & silver. Haven’t
seen any detrimental effects as yet. Actually, you can use any no or
low sudsing soap as a burnishing soap.
