I just wanted to let you know that i have used the bezel punches for years in volume production cast 14k gold and sterling. We hammer the bezels over with these tools and have never broken one. I also occasionaly mount them in a drill press and with the motor on... bear down on the setting to burnish the settings over the stones.
I stand corrected, then. My own use of hammers with these
things, when I first got a set convinced me that using them with
the rocking motion I described was more efficient. Less force
required, and I liked the look better. Budonāt get 70 stones
per hour, either. Maybe I was being too vigorous with the
hammer, or maybe my set of punches wasnāt as good as yours. I
found, using white gold bezels, that the amount of hammering
required to move the metal would occasionally break the punches.
I only broke two, though, before deciding to stop doing thatā¦
For those heavy bezels, I now just use a hammer handpiece, and
use the punches only to help clean up the bezelās shape once
itās already set.
another trick i have is to use a Diamond burr and remove the center of the bezel punch (deepen the center) to greatly reduce the posibility of damaging stones ( i also modified a set this way to set cabochon stones as well) typically we do runs of 500 to 1000 pcs setting close to 70 stones an hour. just thought i'd let you know.
Iāve tried two modifications of these punches, both of which
worked well for me. In one, I ground a series of radial grooves
into the inside surface, and polished them. This made it a much
more agressive burnishing tool when run in a flex shaft. Instead
of just a smooth rotating surface doing little other than
generating friction, the bumps made it act as a series of actual
burnishing tools rotating around the bezel. The other trick I
did was to take a thin (.009") seperating disk and cut an angled
slot across the wall of the punch, and then take a hard burnisher
on the inside of the wall, running it down the slit, to raise a
burr on the trailing edge of the slit. That turns it from a
burnishing tool into a single edge milling cutter, which shaves
down the outside bevel of an overly heavy bezel rather
agressively when used in the flex shaft.
But Iāll stick with my recommendation to at least get used to
using this tool manually before getting to agressive with it in a
drill press or flex shaft. Among other things, used manually, you
have great control over the tool, and itās results. Once you
learn it this way, you always have the option to use it in other
ways. If the only way a jeweler gets used to using it is with a
power tool, then the chances of someone going back to the manual
āharderā method is slimmer, and thatās a loss, I think.
Thanks for the comment.
Peter Rowe
