I just set up my Smith Silversmith acetylene/air torch, using an MC
acetylene cylinder. After checking for leaks (none found), I fired
it up, and the torch seemed to operate fine. After shutting the tank
valve, and loosening the regulator key, I bled the hose by loosening
the torch handle valve and waiting for the HOSE pressure valve to
read “0”, then loosening the REGULATOR valve by turning it
counter-clockwise. The TANK pressure gauge, however, still reads at
approx 250 lbs psi, even with the tank valve tightly shut. Is this
to be expected? I would think that shutting the tank valve and
bleeding the hose would cause all gauges to read “0”.
Jerry
