Torch for cuffs
I have been using a Little Torch for all of my jewelry work, but I
don’t want to tackle another cuff bracelet until I can get a bigger
torch. Where should I go from here to get a bigger torch for cuffs?
Can I use the Little Torch and a bigger torch with the same tanks
without a lot of change-out? Will I need an entirely separate setup?
Which torch do you recommend?
J. S. Ellington
jsellington@cs.com
I use “Y” fittings coming off my regulators so that I can use both
my little torch and a larger torch off the same tanks. It works
great and if need be I can use both torches at once (for heating
below, and above). I believe you can get the fittings at any welding
shop.
Lisa
Lisa Hawthorne
2004 NICHE AWARD WINNER
@Lisa_Hawthorne
