Hello! I have the same issue on a pendant and ring. Both have a mix of stone sizes, and the bezels/tube settings are intended to touch … but when I go to solder the finished bezels together it seems obvious that I won’t have enough ‘access’ to set the lower/smaller stones. (Some are as small as 1.8mm.) I usually set with a pusher and/or rocker, but it seems like even the bezel punches need more access than I’ll have. Advice would be appreciated!
Thanks,
Roxane
