For jump rings, don't you have to heat the entire chain?
Certainly not! If you did that, you’d likely end up melting the
solder in every link, and you’d probably end up with a solid
chain!!! Heating the whole piece when using silver, would translate
to heating the whole jump ring to be soldered rather than just the
joint in the jump ring, but in the case of jump rings for chain,
chances are that due to the size of the ring compared to the flame,
you can’t help but heat the entire jump ring anyway.
How do you solder a chain without using tweezers? (understanding
that tweezers can become a heat sink)
I actually do solder chain using tweezers as a heat sink. I find
that it enables me to make very fine chain (for handmade chain that
is, and don’t ask how fine, as I have no idea; I just mean fine for
me, which of course would be chunky for manufactured chain). It’s
easier when making chain, to solder half of the links closed first,
then join them using the open links, soldering them closed by
holding the two already joined, adjacent links in the tweezers. I
hold them in such a way, that the link to be soldered, can still be
moved back and forth. That way, the “loose”, unsoldered link can be
heated up to solder melting temperature, without the adjacent links
(which are being held by the tweezers) heating up to anything near
that temperature, i.e. you can heat the single, “loose” link to red
heat, without the links in the tweezers changing colour at all. The
use of tweezers helps to avoid melting the links together. That
technique works of course, for a simple cable chain, but probably
not for a more complex chain; but complex chains often have
unsoldered links anyway. They often don’t need to be soldered, as
the complex design of linking with multiple links (as in say a rope
chain) allows the chain to have plenty enough strength even without
soldering. Loop in loop chains are great, as you solder or fuse
(depending on the metal used) all links closed and then “weave” the
links together, after bending them into “U” shapes.
Instead of using sheet solder and cutting snippets, my teacher
taught us to run the wire through the press slightly, have any of
you done this?
I have used wire solder occasionally, and ran it through my rolling
mill to flatten it. Alternatively you could use a hammer and hammer
it flat, then cut into snippets. I used that method when using some
solder wire that arrived far too thick to cut into small enough
pieces. Some solder wires (eg, gold) come as very thin wires, so
they’re easy to cut into tiny snippets anyway. But I do prefer using
sheet solder, first cutting a “fringe” into the sheet, then cutting
across that fringe to make tiny snippets.
How can you prevent cooking off the solder as you use it?
Do you mean the solder or the flux? The solder won’t “cook off”, but
some lower-melting temperature metals in the solder alloy, (the ones
that lower the temperature of the alloy itself, and thus make it a
solder rather than just an “ordinary” alloy) CAN evaporate, and thus
change the solder’s composition, which I suppose could render it
useless, or perhaps make the joint brittle and pitted. I would
imagine that you’d have to severely overheat it for quite a time to
cause the solder not to flow at all, due to losing lower melting
temperature metals from the solder alloy.
If you heat too hot and for too long, you can “cook off” your flux
though. Then you’d get into trouble with the metal oxidising and the
solder not flowing anyway, if it hasn’t already flowed. The key is
to get in and solder as hot and as quickly as possible, rather than
with a cooler flame for a longer time, as getting up to solder
temperature slowly is how you run into problems with evaporating
your flux and/or metals in the solder alloy.
I hope that makes sense; I do tend to waffle on, in the hope of
being understood. Other folks probably explain things better, or
have a better knowledge of it than I do.
Helen
UK
