Allow me to say that this is becoming ridiculous and is making no
sense. What I see here is, in my view, not a discussion anymore, but
a regression of it. This is my last contribution to this thread.
“You are right all metal we work with starts out as a cast ingot.
However I was referring to the casting of jewelry or findings not
ingots in my post.” (Jim Binnion).
Well, this is a nice one. So if you cast sheet and wire, etc. -
ingots - and then you fabricate jewelry from it, it is handmade, but
if you cast as much as a finding your piece is not handmade. Note,
however - and this is important - that there is no basis for this
interpretation in the text that you have cited and that you
introduced to this discussion - I asked you before to point to one
sentence, one part of a sentence or to one word which supports this
reading in paragraphs (a) and (b) of section 23. I am still waiting.
“Well if you want to use the dictionary then Miriam Webster provides
the following synonyms for reproduction: REPRODUCTION ,DUPLICATE
,COPY, FACSIMILE ,REPLICA …”
Well, if Miriam Webster does indeed see these words as synonyms for
reproduction then this dictionary is even worse than the text of the
FTC which started this. For, please, can I ask to think for yourself?
If casting reproduces something, what exactly does it reproduce? The
wax model, you say. But the final result is in metal and the wax
model is gone. Are these differences irrelevant or are they
essential? They seem essential to me, and to Webster too, since, to
her, reproduction results in an imitation of an existing thing (not
that this is precise language, I assume that she means that the
original continues to exist after a reproduction of it is being made,
the same cannot be said of casting). If casting duplicates, what
does it duplicate? Do you end up having two wax models? I really
begin to suspect bad will here. It is obvious that the object of mold
making is to duplicate an object. This was never a point in the
discussion. No molds can be considered to be handmade. The words
’individual piece’ exclude all molds.
If you really intend to split hairs, you could make your case much
stronger if you would be able to give an example of a reproduction
outside the sphere of jewelry making in which an object gets
fundamentally transformed in its nature while being ‘reproduced’. For
then you could reason while using analogies. However, I was not able
to find one. The reason for this is that reproduction does not deal
with the phenomena we are talking about. For example, a synonym of to
reproduce is to procreate. The ‘reproduction’ of two dogs is another
dog. The reproduction of a text is another text. The reproduction of
a wax model is a wax model. Casting, per definition, means
transforming the wax model (and destroying it). People do not cast
in order to reproduce a wax model. It is simply not the same.
‘I am merely pointing out that In the strict interpretation that a
casting is a reproduction. There is no discernible difference between
one copy and the next in a casting.’
I - and others - are merely pointing out that this 'strict’
interpretation is, in fact, your personal prejudice since there is no
way to prove black on white that the text excludes casting. We have
been dealing with ‘manually controlled’ and other parts of the text
before, making the point that they all can be read in a way which
includes casting. However, you do not discuss this interpretation,
you only disregard it. The point that you make in your second
sentence is incorrect: it is not true that there is no discernible
difference between one copy and the next in a casting because
casting does not create copies. If you want a copy, you will have to
make a mold first, which is the act of duplication of a piece and
then, indeed, on the basis of this mold, you can create thousands
of identical wax models which the process of casting will materialize
in metal. Casting does not create any copies by itself. It realizes
the piece in metal. Furthermore, it is also impossible to discern
differences between fabricated pieces if the maker knows his job and
if s/he has the intention to produce identical pieces. Even I can do
it, so it certainly is not too difficult. And finally, and this not
merely a matter of taste, I do not like the term artisan for jewelry.
It doesn’t fit in. In Belgium are big breweries which produce their
beer ‘industrially’, while other people (often family businesses) are
making artisanal beers. Some people also make artisanal clothes. The
word artisanal denotes objects or products being made with an eye to
tradition - in the old ‘authentic’ style - outside the main
economical processes in which the politics of scale are dominant.
But for jewelry, I find it confusing. If I make something with my
hands (including ‘manually controlled’ operations), it is handmade,
nothing less, nothing more. I do not agree that there can be an
infinite multitude of views on this. I think that Lee Einer gave a
pretty accurate definition of handmade, but the problem is that those
who do not agree with it ignore it. I don’t know exactly why I am
quoting this now - let’s call it association - but one of my favorite
quotes comes from Albert Einstein: ‘Don’t quote, just tell me what
you know’. Will
