The Art of Enamelling on Metal by W. N. Brown, 1914
This 1914 book is a very important early book on enameling. It is 65
pages of good, solid The first edition was in 1900,
this version was published in 1914. It has excellent, thorough
detail on enameling and making enamels, interesting to glass workers
and ceramicists as well as enamellers.
The chapters include:
Vitrifiable Pigments: Whites, Yellows, Greens, Blues, Reds, Purple of
Cassins, Blacks, Greys, Brown, History, Cloisonne, Champsleve,
Translucent Enamel Style, Surface-painted Style Cloisonne and
Champleve enamels. Painted Enamels: Apparatus, Furnaces and muffles
for firing, The copper base or plate, Planishing, Champleve.
Composition and Preparation of Enamels: Trituration, Washing, coating
a plate with enamel, Firing ordinary plaques for painting, designing,
Squaring off. Designs for cloisonne and painted enamels: Technical
processes, Brushes, Colours, Grisaille, Full coloured designs.
The introduction is extremely logical and clear, and pretty
accurate. There are recipes for base fluxes. There is an early
mention of water decomposing some enamels and fluxes. There is
mention of uranium colors, which would be unthinkable today. White,
yellow, green, blue, red, black, grey and brown enamel are
extensively discussed in terms of what chemicals and oxides are used
to make them and vary their colors.
There are many drawings and illustrations throughout the book, of
historical works, tools, equipment and so on. Most are engravings,
and are very good.
The history of enameling is addressed, starting before ancient
Egypt. Instances of enameling on pottery and even bricks are
mentioned. The author divides enameling into four main styles.
Cloissonne, Champ Leve, translucent enamel (what we would today call
Basse Taile) and surface painted enamel (called Limoge today).
There follow in-depth chapters on each technique, heavy on the
history and historical examples. The relationship of painting on
porcelain to painted enamels is described.
There is an extensive section on making your own enamel furnace
using ‘fire-clay’ or ‘Blue Pot’, the latter a mixture of standard
clay with graphite (called black lead back then). They were fired
using coke or charcoal and a ‘muffle’ (a separate flat bottomed kiln
insert in which the enameled work was placed into the fire). Trivets
to support the enameled work while firing were made of ceramic, in
the form of round pucks called ‘cheeses’ and thin plates.
Pickling and cleaning the metal to be enameled in described, using a
badger hair brush to scrub it with. Planishing the metal is briefly
touched on. An extensive chapter on making enamels and fluxes
follows with much detail and many recipes. Grinding and washing
enamels is dealt with.
Making a mucilage of quince pips is described for what today we
would use Klyrfire or gum tragacanth. The whole firing sequence is
thoroughly described, and the importance of gently heating the
enamel at the start of firing is emphasized.
A method of copying and enlarging pictures using a grid called
‘squaring off’ is shown to allow less artistic people to copy images
for enameling. Cloissone work is discussed for its similarity to the
design and technical issues found in stained glass work. He uses a
litho crayon to sketch out designs for painting as it sticks to the
enamel better than a graphite pencil.
All in all a pretty good introduction to enameling, especially if
you are interested in what chemicals and oxides create and change
color, melting temperature and expansion and contraction. An
interesting read for enamellers who will be bound to pick up a tip
or two, and who will probably appreciate the pre-prepared enamels
and equipment that suppliers have today.
File Size: 5.44MB, 65 Pages
Download the full eBook at the ridiculous price of $5.
