Interesting concept.... insurance covering you for being a lousy
setter
Some gems have internal stress and putting pressure on one place can
result in the gem shattering.
I have done some gem faceting in the past and I heard stories of
large expensive tourmaline crystals that were being being prepared
for faceting by an experienced cutter, removing the outer skin caused
internal stress to be relieved and the result was that the crystal
shattered.
No person who sets gems can know the internal stresses that occur
from the growth pattern of a crystal, some gems have something
similar to a knot in a piece of wood. Some gems have cleavage planes
that are not apparent until you put pressure onit and an internal
fracture develops.
Insurance is not for being a lousy setter, it is for surprises
thatoccur from what is not observable by the human eye when skill and
knowledge are not enough.
Which gemstone is set the most? Which gemstone has a cleavage plane
that make setting triangles, marquise, pear,and most notably princess
cut much more susceptible to breakage? Diamond. I have seen a
diamond cleave while being set, an edge of the girdle breaks off, or
most of the top popped off at an angle.
I set most of my own if I have something I know I cannot
afford to replace, I have someone with insurance do the work.
Perhaps this means I am a lousy setter, but I am wise enough to
limit my liability.
Learning your limitations is part of the process, and with setting,
my experience is that there is a life long learning curve. I can
never take anything for granted regardless of what I have done in
the past.
Last but not least, removing a gem and resetting it during repair on
a piece that I did not make, I become responsible for anything that
happens as a result of how the seat was originally cut and how well
the prongs were prepared so the gem is properly supported, so pushing
a prong down does not cause the gem to shift and lead to damage from
chipping the girdle.
Richard Hart G.G.
Denver, Co.
