I was asked off list, again by a list member that was worried
that the list would not like or benefit by a question about steam
casting or something simple. I am getting several every night off
list, so I am fairly sure that other would like the same
but are affraid of asking on the list. So, please,
use the list, members that do not have any interest in steam
casting can delete it quickly as I do about many things that are
far above the jewelry making that I do. I am a silversmith and
caster, but I enjoy alot on this list that is way beyond what I
do, I delete the rest.
The question was can you do pewter casting with the steam
process and the answer is: âyesâ. However, there are some changes
that will have to be made for pewter. I will try to cover those
changes as we go.
A reminder that we will also discuss more on the new list at Jewelrymaking@listbot.com for the beginners, amatures, small
quys (like me), rockhounds where no question is too simple or
unwanted. â
Don Norris @Donald_Norris PO Box 2433 Estes Park, CO
80517
For all you lurkers and beginners out there, a little bit of
advice (or severalâŚ)
The only really dumb questions are those that should have
been asked, but were not. Donât be embarassed to ask questions
here on Orchid, rec.crafts.jewelry, or any other net forum, or in
a class, or of those you know, for fear of boring the group or
asking overly simply questions, or whatever. THAT is dumb. The
questions may indeed be simple to answer, or obvious to those who
already know the answer. But ALL of us were also once
beginners, with similar questions.
Sometimes you learn the most from making mistakes, or being
wrong. If youâve an opinion or an answer to a question, donât be
shy. If youâre wrong, those who think they know different will
tell you. No harm in that, and you learn something. If youâre
right, and some tell you you are wrong, then before it ends, THEY
will learn something. And we all have a nice conversation doing
it. The principal also applies in the shop itself. You
sometimes learn more from having things go wrong, so you have to
figure out how to get it to work right, and why, etc. If it just
goes right the first time, youâve learned only that, with little
supporting info about why, or what can go wrong. So donât be
afraid to make mistakes, or be wrong. Great way to learn. And
everyone you read on this, or other lists, has at some times,
(usually Many times) been wrong, both in public and private.
Donât worry about it.
The concept that one must only ask or post messages that
will be sufficiently weighty to be of great interest to all on
the list is just silly. Weâre all here with our own viewpoints,
varying degrees of expertise or percieved expertise, and what the
heck. Weâre all here reading stuff on the computer instead of
working on the bench actually making things. Itâs both a
learning opportunity, a teaching opportunity, and a great way to
get out of having to spend some time actually being productiveâŚ
Donât be shy. Donât feel you must make sense or display lofty
levels of intellect⌠Heck, without some beginners to ask
simple questions how and then, the rest of us would have less
chances to impress ourselves with our knowledge⌠(grin) We
NEED you beginners around here, asking us for our help. Makes
us feel good⌠And sometimes, with just a little luck, we might
even give you some useful info now and then. If you donât ask,
or somehow feel you should only ask in a group or list
specifically devoted to beginners, then youâre just missing the
whole point of a forum like Orchid. There is no such thing as a
question or problem that is too simple or too basic, or too
idiotic, so long as itâs at least remotely âon topicâ.
How about some of the others that use different methods of
casting give us dummies to casting a step by step run down on how
to do it and the advantages/disadvantages of each method.
You can also do 1 off pewter castings in certain Silicone
rubbers âGravity pouredâ with good success provided that the items
is vented (from the lowest area)going back up towards the pour
area at the top of the mold( do not vent into the pouring area,
but next to it).the vents should be v shaped knife cut lines
about 1 mm in width. Vent all areas that do not fill well⌠and
allow the mold to cool between pours or the rubber will
deteriorate.You can use many types of pewter based alloys.Pewter
is in actual fact pure tin⌠but be careful as many people state
that something is pewter, when in fact it may have other alloys
including possibly Lead. This is an excellent method of
converting your wax into a metal model with no equipment beyond a
torch and a crucible for melting and allows you to keep your wax
carving.You can also use heat cured silicone molds to pour
into(Vulcanized) Dan Grandi
Good idea, David. I would love to see that! I am too busy with
the steam casting thing. I want every one to know that steam
casting is just a good very cheap way to get started for a
beginner. It can be used to pay for other equipment: vacuum or
centrifigal, or both. After steam casting I do plan to continue
class on the new list for beginners.
PO Box 2433 Estes Park, CO 80517
Pretty easy to do. Pewter melts so low you can cast it into
almost anything that doesnât actually burn. People cast pewter
routinely into molds made of the RTV silicone rubbers (be sure
itâs a silicone, not all RTVâs are). You can also use normal
casting investment, for lost wax. Cast it with the mold just
warm enough so you know the pewter isnât going to hit a bunch of
water. Warm to the touch is fine. Doesnât need to be hotter.
You can cast it in well dried room temp plaster of paris too, if
youâve made a mold of something like a clay form. Remember,
though, that plaster of paris wonât take the temps needed to
burn out a wax model, so itâs not for lost wax casting.
Traditional pewtersmiths sometimes would make molds for things
like handles of coffee/tea pots simply by cutting them out of
wood, or plywood. You can cast several rough forms in the wood
before itâs started to char too much to hold the detail (these
are intended to be filed and refined a good deal after casting,
usually⌠Use a decent soft soldering flux (zinc chloride type)
when melting the pewter, and skim the dross off the molten pool
just before you pour the mold. There are better, specific
casting fluxes for tin alloys, but the zinc chloride has always
worked well enough for me. Pewter solidifies slowly enough that
usually, a plain gravity pour is just fine. You can use a vacuum
or centrifuge if youâve got one, and results will be better.
Remember to let the machine spin down completely by itself. If
you stop it early, the pewter may still be molten, and will just
pour back out again.
Vent your mold well, have it 50 degrees less than pewter melt
temp and pour after scraping sludge from crucible, put a wet
thermal or rag [watch for fire] and cover with a board of
sufficient weight on top of the mold and wait to cool. That
should be itâŚ
John the âRINGMANâ
PS
the vents should end inside the mold except for two which should
be on the outside top across about the size of the 0âŚ
I don't consider myself a 'dummy' but I have never cast pewter
and would welcome (esp. details) on how to go about
it.
Lorri, I will cover casting small pewter piece with steam as we
go along. I worked for one of the largest pewter casting
companies in the USA for three years. Steam is not the best way
to cast pewter, but is the cheapest!
You can use many types of pewter based alloys.Pewter is in
actual fact pure tin... but be careful as many people state
alloys including possibly Lead.
Hi, Don
My references say that pewter is always an alloy. Older pewters
were tin-lead in around 4-1 proportions. Modern pewter is
approximately 91% tin, 7.5% antimony, 1.5% copper, but there are
variations.
When I was in school, working in pewter was looked down upon.
Apparently, pewter can contaminate your work surface, or
something like that? It was recommended that, if you were to work
in pewter, you set up a separate work station for this. I do not
know any details, and I could perhaps just be remembering this
all wrong. Can anyone supply me with the deeper knowledge
Regards, Kirsten in PA
all wrong.
You remember correctly. Do not use the same tools when working
with pewter. It should be kept seperate from all your other
metals. It is mostly tin 91%. with a 7.5 % antimony and copper
1.5%, and melts at around 435â. The lead was outlawed quite a
few ago. I first learned it in '77 in Connecticut, and have done
it again here in school-SDSU with visiting instructor Fred
Fenster, who is well known for his pewter work. Maybe someone
else knows where he is. Might search the internet for him. I do
have an old paperback book from Dover Publications, 180 Varick
St. NY NY 10014, called âPewter-Workingâ and it has a chapter on
casting which you might find useful. Louise-- San Diego @lgillin1
The problem is that pewter (tin), and for that matter similar
metals like lead, if placed on a piece of silver, copper, gold
alloys, or the like, and then heated to the normal soldering or
annealing temps for those other metals, will melt long before
that point, and in essence, burn into the other metals. So if
you work pewter in the same area as you also work silver, you
run the risk of little bits of pewter, such as filings, etc,
being on your silver when you solder or anneal it. Even little
tiny filings will leave deep pits in the silver. Larger bits can
burn holes right through a piece of thin sheet metal. This is
generally not something you wanted to happen. Thus the need to
keep pewter and similar low melting metals (including soft
solders like stay brite, tix, tin/lead, etc) seperate from your
work with higher melting metals.
You donât absolutely need to have a seperate bench to work with
pewter, if youâre careful to clean up completely when switching
between metals. But itâs a lot safer to use a seperate area if
you can do so. At the very least, use seperate soldering
pads/surfaces, solder pics, and the like⌠Be sure, also that
your files, used with pewter, donât retain bits of pewter in the
teeth which could then come out later and contaminate your
precious metals. Itâs easy to do by accident, and the scars that
result can be a royal pain to clean up again.
A somewhat similar situation, by the way, also pertains to
working with platinum. In this case, platinum can be similarly
contaminated by filings and other bits of gold or silver, which
will burn into the platinum if heated to the normal soldering and
annealing temps of platinum.
pewter has lead⌠It contaminates nobel metals as lead wants
to include itself in the alloy and compromises the structure of
the nobel metals. never lead solder silver or goldâŚ
The ringman
Antique pewters sometimes contained lead. Modern pewter does
not. Itâs mostly tin, with a bit of antimony and copper. The
tin will contaminate other metals just as readily as does lead.
The ringman
Iâve just started to work with pewter. In my reading I keep
seeing that pewter no longer contains any lead, not since some
time in 1700. They say that pewter contains 91% tin, 7%
antimony, and 2% copper. They continue to say that its not a
good idea to use the same tools that are used for your silver and
gold. Is this still the case? Frances
Francis: Sorry about the misI repair antique
Jewelry and some of the pewter contained Lead, later on I ran
into some homemade pieces that were alloyed with an old recipe so
that is not always the case. The antimony and tin are also lead
like in their behavior causing the metal to be compromised. Again
My apoligies. Ringman
Yes. tin melts in the same low range as does lead. Both
metals, if sitting on a piece of gold or silver that is being
heated to the annealing or soldering temps for gold or silver,
will melt their way deeply into that metal, causing significant
scaring. The biggest difference is that lead added to an alloy
of silver of gold can make it less workable and even brittle.
Tin is not quite so damaging as an actual alloy constutuent.
