Amanda
As soon as I saw your original post I followed closely on all
replies. I decided not to post my own thoughts until I got the
general ‘gist’ of the advice given. Somehow I think that most of the
posts are within the general atmosphere of what it is you need to
hear but there are no specifics. Yes writing down a business plan is
a good idea but before that, I think you must decide EXACTLY what it
is you want to do and how to do it. From your original post it seems
to me that you have a general idea about where and how to go about
this.
You know it is very funny because I myself have recently started my
own production line too. The reasons for this are quite simple. I
started out in handmade one-of-a-kind pieces but unfortunately apart
from the occasional wedding there wasn=92t much of a market for it. I
live in Greece and in a small suburban place so it is very difficult
to market this kind of work. I therefore decided that I needed a
larger audience. So what I decided to do was learn wax carving and
start my own production line(s) without actually abandoning my
handmade pieces (on the contrary wax carving opened up more creative
opportunities for me).
So my opinion is this.
First of all you need to see what your own capabilities are. What is
the extent of your technical knowledge and expertise. Secondly you
need to see what the demands (both in technical terms as well as in
terms of finance, time etc.) are going to be for starting your own
production line. Taking your own designs to a company to produce
from start to finish will probably be a costly endeavor. And it is
also not certain that these designs will sell.
Secondly =96 one thing production line jewelry has taught me =96 you
need to see how you can make your production more efficient. What I
mean is that you will need to have certain parts cast or make master
pieces in order to save time.
One of the differences between one-of-a-kind pieces and production
line jewelry is that in the first case you make the piece from
scratch and you go through the whole process beginning to end.
Whereas production line jewelry has the advantage of casting certain
parts or pieces and thus you save time in the construction process.
I think what you need to do after you see what you are capable of
making yourself and what not, is to decide whether to invest in the
machinery and knowledge in order to do this yourself or to
subcontract the work entirely to someone else. Now both options have
their costs but it all depends on how you want to go about this.
If you decide to invest in the machinery I don=92t think you=92ll need
to spend a lot of cash. I do my entire production by using a
vulcanizer and a wax injector machine. The actual casting is done by
a high standard professional caster =96 I had to search around a bit
and reject the first one because of poor casting results. Therefore
since I don=92t have to get into the job of casting my pieces I can
pour more money into the equipment I have and need, as well as the
materials and tools. My vulcanizer and wax injector are very high
quality machines and that ensures the highest standards in every
phase of production. The other, and perhaps more important, thing
you need to do is expand your knowledge. You are very lucky in the
fact that in the States you=92ve got some truly excellent wax carving
teachers and instructors. My recommendation would be to go and learn
wax carving. It will open many more creative doors for you. It might
be a bit costly as far as the tuition goes but believe me it is well
worth the cost. The next best thing, if you are not willing to go
through the process of learning wax carving, would be to hire a
professional wax carver and work closely with him/her. I don=92t know
what other emails you=92ve received as far as offers are concerned but
I noticed that Ms Mersky made you an offer. Check out her site. She
does brilliant work. Once you get the master models ready then you
can make any kind of modifications on them in metal =96 even to the
extent of making an entirely different looking piece from the
original. Depending on the arrangement you=92ve got with your wax
carver you could probably keep the molds, make the wax copies and
send them off to the caster. It would probably be a good idea to
have several wax copies stored in stock so when the need arises
pieces can be sent immediately off to the caster with minimum delay.
As far as your handmade pieces are concerned, it would be a good
idea to have certain parts of them standardized (i.e. the findings
or any other parts that can be modified in metal) and make molds out
of them. Believe me the time you=92ll save on these little things will
be a great help to you.
Well that=92s it for now. I=92m sorry for rambling on and probably
tiring you and other Orchidians but because your case is so similar
to mine I feel for you and understand the dilemma you=92re in.
I hope everything goes well for you and the best of luck with your
endeavors.
Lee Lyssimachou
Lee Feenix Art Workshop
Greece
