Materials: Sterling silver & 18ct gold
Dimensions: 26 x 26 x 7.5 cm
Hand-raised sterling silver bowl with an oxidised inside and 18ct gold staples running up a ‘crack’ cut into the side of the bowl reminiscent of the way porcelain plates used to be repaired.
Photo credit: Kirsty Eaglesfield
Kirsty Eaglesfield
Edinburgh, UK
Kirsty Eaglesfield’s contemporary silverware and jewellery is inspired by the way the sea weathers and erodes objects changing their form, colour and texture. Tumbled piles of fish crates, old buoys, pieces of sea-washed glass, driftwood and the construction and shapes of boats are all central to her work as a silversmith. Used, worn objects and the way they have been patched-up and repaired, often modified for a use different to the object’s original purpose also inspire her. She works primarily in silver and wood, often incorporating pieces of scavenged, collected flotsam. She enjoys exploring the different ways each material can be worked with, textured, formed and treated to convey a sense of the sea and likes to add a bit of colour to her work using enamel and semi-precious stones where possible.
