G’day I often find a need for steel stamps. I make these from
round tool steel (I think you call it drill steel or carbon
steel) Simple patterns like stars, shells, hearts, diamonds, etc
can be filed at the end of a rod using swiss files, binocular
magnifiers and patience. Slightly more complicated patterns can
be cut using a rotary handpiece and diamond burrs; for instance I
have replicas of my logo to unobtrusively mark my work. One is
5mm diameter and the other only 2mm. Not too difficult even
though I’ve become a bit ham-fisted these days. When the pattern
is satisfactory, heat the end of the tool to cherry red and
quench by waving it in a bowl of water. It will now be dead hard
and so brittle as to break first time you try to use it. So
clean off all the black with emery, then heat about an inch back
from the end with a small hot flame, whilst rotating the tool
rod. You will see colours where the flame touches the rod. These
colours will slowly move down the rod and when the end is straw
(medium yellow) stop heating and immediately quench. And there
you are; an El Cheepo metal punch. Have a go. But buy those
to stamp ‘x ct’ ‘STG’ or ‘925’ They’re a bit too tricky to
carve. Why do you think my logo is so simple? Cheers, –
/ / John Burgess,
/ //\ @John_Burgess2
/ (___)
(_________)
