I am looking for a source for small amounts of small mixed stainless
steel shot to use in a tumbler for polishing silver. All the sources
I have found want you to buy ten pounds worth. I’ll never ever use
that much. A pound or two is all I need.
Howard Mayling
PO Box 55717
Riverside, CA 92517
(909)369-6648 FAX (810)963-6067 @Howard_Mayling
Howard, I think you will find you need far more than you can imagine.
Shot is quite heavy, and a little does not go a long way.
I was trying to economize some time ago and went into industrial
liquidators and salvage shops looking for small screws and nuts to add
to the round balls I had already bought. I had to order more packaged
shot, as the small packages never made up the volume I needed. Teresa
