Can some one tell me where I can purchase a tungsten carbide square
hole draw plate that goes down to hole size.26 mm. I have not had
good success drawing very small fine gold wire on steel draw plates.
Thank You Jerry Huddleston Engraver.
Jerry have you tried a little burr lube on your wire before you
start your pull? Wax will also work.
Frank Goss
Frank.
Jerry have you tried a little burr lube on your wire before you start your pull? Wax will also work
Thanks for the tip but I work almost exclusively with 24K and it
just doesn’t pull well in small sized thru a steel plate.
