I’m confused - if the metal thickness is to be 0.8mm then the inside
diameter must be 10.2mm. No wonder you are having trouble finding
someone to make the tube.
-outside diameter 11.8 mm -tube thickness 0.8 -inside thickness 11
mm
I think you need to take a closer look at your requirements. This
would be impossible to make.
If as you say, the outside diameter is 11.8 mm & the inside diameter
is 11 mm; the tube thickness can only be 4 mm. If you want a.8 mm
wall thickness the OD must be 12.6 mm if you need a 11.0 mm ID or the
ID must be 10.2 mm if you need a 11.8 mm OD.
mm
You will never find a source at least in this universe. The numbers
just don’t add up, with an ID of 10.2 it is possible but probably
difficult to find short of a custom order.
A draw plate even made with mild steel will last a long long time.
Besides, while making wire or sheet can get boring really quickly but
there is still some sort of magic for me in pulling tubing.
Jeff
PS: If you get really desperate contact me off line, I won’t do
major amounts and have no cheap workies on staff, but also don’t have
the minimums of a refiner.
You can always make yourself a drawplate with just afew holes and
the 12.6mm as the final size. Draw the sheet strip around an 11m mm
rod to get an accurate size. Not as hard as it might seem, you can
buy tool steel bar and harden and temper it so it can be used many
times.
