Hi Op shops (opportunity shops) are charity shops that sell all
kinds of second hand goods.
Usually they carry all sorts of kitchen things and are very cheap.
Salvation Army and St Vincent de Paul aka vinnies in shop.
The idea for galvanised tin came from a bench I saw in a torch
supply shop.
It is great if you drop something hot on it does not burn or corrode
and is really cheap.
Also easy to clean up. The metal shop will cut to size the edges
needs sanding!
I also have stainless steel bowls with little black rocks in them
for heating hollow ware. Forgot what they are called decades old. You
can seem them on Leonid’s blog.
I have one mounted on a rotating chair assembly, buy a cheap chair
from the op shop and Frankenstein it, as in Frankenbench, don’t you
just love the technical terms we jewellers use. You can turn your
work around very easily. I put a soldering block on one to solder
large bezels easy to turn round and get the heat all over the piece.
Also I have an extraction fan on the soldering table and the fire
extinguisher on the door frame for easy access.
Never had to use it but you never know.
Also my soldering bench is next t a sink, burns are cooled with
running water. When I did not have a sink I had a bucket of water
close by.
Back in the days of no compensation/sick leave some jewellers who
had small second degree burns ran a torch over them to make them third
degree, no pain but nasty scar. That was back when some shops in
Northern Europe ran on beer, and the left overs went in the scratch
brush dip. Left over beer is something Australians cannot understand.
Positively Medieval, those were the days in Britain when you did not
marry women for their looks or personality but how well they could
brew the beer. The rich drank wine as water was not usually fit to
drink.
Beer, wine and lead hollow ware explain a lot of Medieval history.
Richard Hopkins
