Does anyone know of a good source for thin and pliable suede that
can be used for necklaces? I see similar suede used in lots of
trendy jewelry, but I can’t find a source for anything except the
standard 1/8 inch lacing that is rather stiff. I’d love to find a
variety of widths-somewhere around 10mm would be ideal. MJ Trim has
ultrasuede and is the closest I can find, but it is too stiff.
Thanks so much! ali www.alfmetals.com
Ali, You have to cut your own from suede skins. They are very easy to
cut with scisors – or a sharp matt knife and ruler – mark with
dressmakers chalk so you get clean strips. My favorite leather
resource in NYC is Libra Leather 259 W 30th St 212 695 - 3114
They only have top quality – tell them you need a few peices for
samples.
Good Luck ,
Adrienne
Aloha, You are looking for soft suede lacing, yes? Go to
www.firemountaingems.com and type in the search box: WE1322BS and if
you type in their search box: suede leather this is what you will
get: SUEDE LACE BLACK 25YD SPOOL EA
Order # WE1388BS - IN STOCK - Quantity Discount
Pricing 1 2 3+
$ 11.36 $ 8.91 $ 7.11
hope this does the trick for what you need.
Much Aloha,
Waynette
HQCE
Designer
Does anyone know of a good source for thin and pliable suede that can be used for necklaces?
Ali, you might try Bally Beads (wholesale only) in Rockwall, TX at
800 543 0280. When I was last in the showroom they had spools of
smaller, softer stuff in several colors, though it may have been
ultrasuede also.
Hope this helps,
Donna in Dallas
Try Indian Jewelers Supply: 800.545.6540 or www.ijsinc.com These
are described as top-grain leathers (high quality)
Rio Grande has some too.
Reba.
