Hello
Is there in the market a small continuous casting machine to make
silver sheet and rods tube or square in sterling silver? any
manufacturer’s names?
thks by advance
nathalie
Hello
thks by advance
nathalie
nd rods tube or square in sterling silver? any manufacturer's names?
Are you looking for an extruder?
I’m not sure what you mean by 'continuous casting machine ’ but there
are many electro-melt furnaces that can be run at 100 5 load 24/7
with time for various set ups to be accomplished in that period. You
use a rolling mill for ingots or rods of metal to be shaped into
desireable mill products., An electric one (Durston is a top quality
machine) Casting tube is an interesting notion- it is drawn usually
from larger to smaller dimensions. I would recommend your checking
into some auctions if you are serious. There are many on line
previews of trade equipment. Some you can bid on from wherever you
are and others you or a rep must be physically present to bid and
buy, then there is shipping and FOB vs. DIY jobbing and carriers to
research. I think you should do a bit of homework and peruse a few
trade equipment catalogues first, then come back and ask for
specific solutions. rer.
Is there in the market a small continuous casting machine to make silver sheet and rods tube or square in sterling silver? any manufacturer's names?
Almost by definition the continuous casting machines for precious
metals are small.
Indutherm
http://www.ganoksin.com/gnkurl/ep7zy6
Shultheiss
http://www.ganoksin.com/gnkurl/ep7zy7
Italimpianti
http://www.ganoksin.com/gnkurl/ep7zy8
James Binnion
James Binnion Metal Arts
