Hi Rajah, I know that there is a solution to your problem. I have
done plating on plastic myself in the past. I will do some
research and come back to you. Richard W UK
Thanks for posting queries on my problem… I think it relates to
my query. I am attempting to silver plate polyester objects. I
know it works for others as I have seen the finished products. As
to your question whether I plate in layers? No I have only
attempted to plate silver.
I outline the process that I have attempted and failed.
Apparently due to some hidden secret.
On an ultrasonically cleaned polyester object I spray on my
’Concoction’.
One part Nitrocellulose Lacquer.Diluted with Three parts of
solvent ( Diluted as as per manufactures recommendation -ICI
make ). 50% w/w Bronze powder to the lacquer/solvent mixture. (
Although I have tried different % Bronze between 30% and
60% with no real difference ).
Post spraying I let the oject dry for an hour. ( Have even blow
dried with a hair drier)
Used a standard silver bath. Attempted volts/amps as per bath
salt manufacture’s recommendation ( Heraues of Germany ).
Yes I do get the initial plating. It starts dull and remains so.
If I attempt to increase the current I find the plating beggining
to charr. I have tried varying time slots with no major
difference.
The objective is to achieve a mirror shine silver plating on the
polyester object. As far as I know the same is possible even with
out having to layer plate the same???
so. If I attempt to increase the current I find the plating
beggining to charr. I have tried varying time slots with no
major difference. The objective is to achieve a mirror shine
silver plating on the polyester object. As far as I know the
same is possible even with out having to layer plate the
same? .
Are you examining the surface of the laquer closely before you
start to plate? You cannot get a smoother surface than the one
you startyou start with.
Hi Laura. All I know it is a two part brightner system
recommended and sourced from Heraues Ag of Pforziem Germany. Do
you think the problem is in my plating technique and probabally
the contents and or voltage/current??? Rajah.
Hi Richard I seem to have found atleast one way out that works.
However I still look forward to your notes that would still help.
